ECT - Ford Powerstroke Diesel Forum
Old 05-08-2011, 05:55 PM
ECT
I did the coolant flush with restore and lots of distilled water installed a new thermostat and added ELC replaced the oil cooler and deleted the egr cooler also did the STC fitting while I was in there and also ended up replacing the radiator it started leaking around the bottom tank not sure if the radiator problem was caused by the coolant flush but its possible I guess, my question is that before I did the work my ECT was around 185/190 while cruising now it is at 195/200 as is the EOT I thought after all that work temps would actually be lower?
Old 05-08-2011, 06:19 PM
Ya something isnt right there, cruising ECT should be about 190. Why did you end up replacing the radiator?
Old 05-08-2011, 07:05 PM
i changed the radiator because it was leaking around the bottom tank
Old 05-09-2011, 05:40 AM
You are good to go. The thermostat starts opening at 192* and is fully open at 219*. Your diesel is perfectly happy and operates more efficiently at 200* than it does at 185*.
That is why you can get 202* thermostats for the 7.3. Someone should make them for the 6.0.
My 6.0 runs the same temps with a remote BPD oil cooler. Like Bob Marley says, " don't worry, be happy".
Old 05-09-2011, 05:55 AM
NOT a Democrat
Perfect! New theromostat is working better than the old one!
Old 05-09-2011, 10:00 AM
Smile
thats good news, thanks for the reply you guys are awsome as always
