Coolant level and oil cooler question
837 views 3 replies 2 participants last post by  bismic
#1 ·
when I bought my truck the coolant level was at the full level and since had dropped to about half way between the marks and leveled off. I could see coolant residue on the tank, which I always cleaned off, so I can see if it is puking still. Today I made a 4 hr 70 mph round trip with about 2500 lb load in the bed for half of the trip. I checked the tank and it had puked some. I don't have gauges yet and haven't done a coolant flush yet.
Now my question is if the coolant level is at the min. mark ( which I believe is the proper level if I read right) will the coolant still puke out if the oil cooler is plugged?
#2 ·
Puking occurs mainly because your EGR cooler has failed or you have failed head gaskets (or you have an issue w/ coolant flow). It can also occur w/ an overfilled degas bottle because coolant expands when it heats up.
The oil cooler plugging is a contributor only because it restricts coolant flow to the EGR cooler - which then results in its failure.
Puking can occur at any level in the degas bottle if you have an issue described above.
