Oil filter housing ? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-04-2011, 12:47 PM Thread Starter
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
If I remove the oil filter and let it sit for a while, will I still have a huge mess when I remove the housing so I can get the intake off?
dhanna6powerstroke is offline
post #2 of 4 Old 05-04-2011, 02:06 PM
DesertSmoker's Avatar
I say yes but when I did my oil cooler I drained about a gallon left the rest in and I did not make a big mess.
2003 F-250 CC 4x4 SB 6.0
Custom 03 Turbo, WPE Intake,
HD 97 Fan Clutch, MBRP Y Pipe,
Scangauge II Rancho 9000XL,
BFG 285/75 R16, Galaxy 94HP
DesertSmoker is offline
post #3 of 4 Old 05-04-2011, 02:31 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
No you won't have a huge mess just for the oil filter housing (tower). You'll have just a couple of drips if your drain valve is working properly. I would say it's about as messy as changing out the oil filter. Now if your removing the oil cooler housing, then yes, have a towel laid down over the motor so when you lift the oil cooler housing, you won't get oil drips all over the motor.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 4 Old 05-04-2011, 03:01 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Residual oil inside the filter will drain out immediately, the moment the filter is removed from the housing.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
