EGT probe??? - Ford Powerstroke Diesel Forum
Old 05-03-2011, 05:24 PM
EGT probe???
Hey so as most everyone knows just got my heads back on and running, truck runs great 4x4 doesn't come on whoops gotta see what i didn't plug in lol. BUT more importantly my egt gauge is acting funny, when your cruising down the road it reads give it gas it drops down past 0 like its off then let off it will come back to reading and sometimes it doesn't work at all. Any ideas?
Old 05-03-2011, 05:28 PM
Slacker
Feedback Score: 4 reviews
Sounds like your probe is going out or you have a power problem on the gauge itself. I would suspect the power connection to the gauge. Check the voltage at the gauge and confirm you don't lose voltage when you jiggle the wires.
Old 05-03-2011, 05:31 PM
well, i dont think there is a power/ground problem to the guage i hope not because i didn't disturb anything in cab when i lifted it. but i did remove the probe from the exhaust manifold. will a probe do this?
Old 05-03-2011, 05:34 PM
Slacker
Yes, the probes do go bad. Who makes the gauge?
Old 05-03-2011, 05:36 PM
autometer, i realise the probes go back I was more curious are these the symptoms they have when they go bad? I know my ground is good because gauge lights share same ground i guess i should figure if power is there
Old 05-03-2011, 05:58 PM
Slacker
Mine does something similar when my lights are on so I am assuming that I have a power problem. I just haven't chased it down.
Old 05-03-2011, 06:01 PM
no mine does it with lights on or off sorry about that
