uoa shows 2% fuel in base @ 4450 on oci?? - Ford Powerstroke Diesel Forum
Old 05-03-2011, 12:33 PM
What can I look for. Also when changing stc fitting do I purchase cover orings? also anything else to change after removing hpop cover?
Old 05-03-2011, 12:42 PM
This is my parts list which will also include coolant filter, EAS fuel press sensor for insight, and egr delete.
(1) Fuel press spring 3c3z-9t517-ag
(1) Oil cooler 3c3z-6a642-ca
(1) Stc fitting 4c3z-9b246-f
(1) fuel bolt w302472 "as long as 2 are in pack"
(1) fuel bolt washer w303659 "as long as 2 are in a pack"
(1) thermostat 3c3z-8575-aa
(1) turbo drain 6c3z-9t515-a
(1) intake gasket set 3c3z-9433-be
(1) turbo supply 3c3z-9t516-a
(1) turbo clean kit 4c4z-9v424-aa
Anything else I may need. Thanks
