I just bought a 06 6.0 and after having it 4 days it started to sputter around 55-60 mph. Then it would slow start like the batteries were going dead.
First chance I got I took it in and got an oil change, & fuel filters changed. While it was in I had them check the voltage on my batteries. Turns out I had a bad alternator. New fuel filters did not help the sputtering. Sputtering only happens when accelerating at normal speeds. When I "get on it" it doesn't sputter. No smoke, just a sputter. Could the low voltage from the bad alternator have damaged my FICM? |
Yes it could have you need to check it. use the below procedure or get an Edge Insight CS\CTS and monitor it that way FICM pictures by DrQuad - Photobucket but mine was bad when cold and I had a wavy idle at start up.. Got a 58v Swamps FICM and ![]() my throttle was back.
Did your mileage get better?
