bulletproofing a 6.0? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-02-2011, 06:09 PM Thread Starter
what do i need to do to completely bulletproof a 6.0 to the point where it will be trouble free. my fathers cummins and box truck, both I-6 diesels one cummins one isuzu have never gone down, other than for one day a piece. id love to have a damn near perfect 6.0. i know id have to do the EGR delete, updated oil cooler, head studs and gaskets. coolant flush, fuel filter and id probably pick up a set of aftermarket injectors and maybe an aftermarket turbo. and a tuner so i can monitor EOT and ECT. what else would i have to do to make this truck bulletproof. and is pulling the cab easier than pulling the engine? i feel like doing all this on a stand is alot easier than pulling the cab. i really want to know about this, because im eventually going to own a 6.0. an f350 or an excursion.
SOLD:2000 f-250 extended cab short bed 4x4 xlt 3.73's 6637 DIY intake 02-04 headlights. stock otherwise
SOLD: 1999 f-350 crew cab lariat short bed 4x4 3.73s
2002 extended cab short bed 4x4 XLT fx4 interior 3.73s AFE intake, 305/70/16 toyo MTs plow truck
navistardiesel is offline
post #2 of 12 Old 05-02-2011, 06:24 PM
BurninRubber&BlowinSmoke
jn_h's Avatar
Read through this, he really knows the 6.ohs!
Things to consider about owning a 6.0L
SOLD
06 F250 6.0
Banks exhaust
Banks High Ram
ARP Headstuds
Black onyx hg
Rebuilt oil cooler
Sinister EGR delete
NCHornet's CCV mod
Dieselsite coolant filter
F650 Dash mod w/ Carling switches
08 center console
jn_h is offline
post #3 of 12 Old 05-02-2011, 06:26 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Everything you said except the injectors and turbo if yours are in good shape
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 12 Old 05-02-2011, 08:49 PM
neal_zack's Avatar
add a dieselsite coolant filtration kit and thats pretty much it
Fully Bulletproof kit, BPD EGR delete,ARP head studs, OEM head gaskets,6.4 banjo bolts, Updated fuel pressure spring,SCT TSX W/EGT probe,MBRP 5" straight pipe,updated turbo center section,updated turbo drain tube, Dieselsite coolant filtration,CAT ELC,STC fitting, AFE magnum force stage 2,dual red top optima's,6 inch fabtech suspension lift kit,37" Dunlop Rover MT'S,High Idle Mod,Bradford Built Stepside Flatbed W/ LED Lights, Firestone "Ride-Rite" Air Bag Helper Springs
IRONWORKERS LOCAL 14
neal_zack is offline
post #5 of 12 Old 05-03-2011, 03:10 AM Thread Starter
and is pulling the engine less of a pain than pulling the cab? i know on the excursion id have to pull it. but on the truck?
post #6 of 12 Old 05-03-2011, 02:07 PM
Chango's Avatar
dealers pull the cab because it is more efficient / faster, so I have read on here
Awesome thread on oil / cold start issues for 6.0 ---->
Troubleshooting a no Start Condition --->
Still using Ford Coolant? ---->
Chango is offline
post #7 of 12 Old 05-03-2011, 04:10 PM Thread Starter
yeah but i dont know what to unhook on the dash and cluster and whatnot thats the trick part for me. pulling a motor shouldnt be much of an issue, with that said, theres always something.
post #8 of 12 Old 05-03-2011, 04:51 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
all that stuff is wires, which means there are connectors.
the most DIY unfriendly part of pulling the cab is the A/C and brake lines
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #9 of 12 Old 05-03-2011, 06:14 PM Thread Starter
what do people who have 6.0 experience reccomend?
post #10 of 12 Old 05-04-2011, 06:09 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
The only updated oil cooler that I would recommend would be the one from BulletProof Diesel and is what I run in my truck. The factory cooler is still prone to clogging and the "upgraded" oil cooler with larger coolant passages reduce the risk of clogging, but the heat transfer from oil to coolant is decreased considerably. Look in my signature and you will see all the stuff I have done to improve my reliability and make my truck BULLETPROOF.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
