gas guage/programmer - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-02-2011, 05:21 PM Thread Starter
Sorry about posting here but it was a electronic and a programmer question. I was at a gas station today filling up my truck and while i was doing that i figured i would change my tune (sct). I opened the door while it was reading and retuning, Well when I got finished filling up truck it only showed 1/4 of a tank and my truck said 212miles to empty. I returned it to stock and same thing. Would opening up the door or filling up while tuning mess it up? Any fixes that you all could recomend?
2006 f250 Lariat fx4 CC, SB
Straight pipe
egr delete
sct x3
edge insight cs
country6220 is offline
post #2 of 5 Old 05-02-2011, 05:37 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
IIRC, when you leave the key in the on/acc position while filling up it mess up the fuel gauge. I believe the fix for this was to disconnect the batteries for awhile to clear the memory.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 5 Old 05-02-2011, 05:59 PM Thread Starter
I will do that. thank you very much.
Straight pipe
egr delete
sct x3
edge insight cs
post #4 of 5 Old 05-02-2011, 06:50 PM Thread Starter
Thanks LILPOOH! That worked.
Straight pipe
egr delete
sct x3
edge insight cs
post #5 of 5 Old 05-02-2011, 06:58 PM
Powerstroke Techie
Lilpooh's Avatar
Good to hear!! By the way, according to the SCT instructions, they recommend that you don't have anything on (lights when door is open, radio, ect) while you are programming. Something to do with battery draw can mess up the download if your batteries are weak.
Lilpooh is offline
