Trailer plug in question - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-02-2011, 06:07 PM Thread Starter
airdahl's Avatar
My brother has a 2006 Chevrolet half tone when he bought his inclosed trailer he was going to run the interior lights when plugged in to his truck. When we hooked it up no lights. The dealer said that from the factory the constant power that is sent to the plug is disconnected and they have to hook it up they say it helps prevent corrosion in the plug. My question is the constant power that charges my trailer batteries when I drive already hooked up or do I have to add a fuse somewhere or get the dealer to hook it up? Sorry for the long story just wanted to make sure y'all understood my question
Silverline turbo back exhaust
Airaid intake
SCT tuner w/ innovative tunes
ELC rottela coolant EC-1 rated
20 inch superduty rims
airdahl is offline
post #2 of 12 Old 05-02-2011, 07:41 PM Thread Starter
airdahl's Avatar
Anyone
Airaid intake
airdahl is offline
post #3 of 12 Old 05-02-2011, 07:53 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
This was brought up last week, when you shut the truck off there is a relay switch that turns off the power to the trailer plug on the truck. Your gonna have to run cable from the battery to a separate trailer plug for power or add a battery to the enclosed trailer. I'm sure there might be a way to by-pass the relay switch, but IDK.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 12 Old 05-02-2011, 08:00 PM Thread Starter
airdahl's Avatar
My question is does my truck have power back to my travel trailer when I am driving or the truck is running will the trailer batteries charge?
Airaid intake
airdahl is offline
post #5 of 12 Old 05-02-2011, 08:06 PM
Powerstroke Techie
Lilpooh's Avatar
It should, I know on my 5th wheel when hooked up to a running truck, it charges the battery. You can check this if you have a battery meter in the camper. When not hooked up my meter reads 3/4 charged, but when hooked up running, the meter shows full charge.
Lilpooh is offline
post #6 of 12 Old 05-02-2011, 08:09 PM
It will only charge with the key on.
Austin G is offline
post #7 of 12 Old 05-02-2011, 08:11 PM Thread Starter
airdahl's Avatar
I don't have to add a fuse it should be all set to go? This is set up from the factory.
Airaid intake
airdahl is offline
post #8 of 12 Old 05-02-2011, 08:16 PM
jetjock15's Avatar
Quoted: 113 Post(s)
you have to add the fuse, they do not come with "trailer tow charge" fuse installed when new.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #9 of 12 Old 05-02-2011, 08:18 PM
jetjock15's Avatar
Quoted: 113 Post(s)
at least mine didnt, and the dealer told me they dont come that way. Its under hood, its marked in owners manual so you can check. Additionally you can use a tester on your plug, simple check. its the one labeled "+"(diagram on plug cover lid)
post #10 of 12 Old 05-02-2011, 08:19 PM Thread Starter
airdahl's Avatar
Is this fuse under the hood? How many amp do you use
Airaid intake
airdahl is offline
