Installed my Insight CS...
So as some of you know, I scored and got a brand new CS with two dodge pillar pods for $160.
I couldn't pass that up, so anyways i picked it up today, and got it installed (boy, the new Insight is a pain to setup ).Everything was looking good, FICM read 48.5V on a cold start, battery voltage was around 12V with key on, but then I went and read the DTC's... ![]() Here's the list, can someone explain what actions I need to take? -P006A -P0272 -P0480 -P0528 The thing is, the truck runs great and I don't hear anything wrong with it (injectors misfiring, choppy idle, none of that). So I'm a little frustrated/confused. Thanks in advance! Last edited by SickStroke6.0; 05-02-2011 at 11:40 AM. |
P006A MAP - Mass or Volume Air Flow Correlation (Probably getting more air since you have AFE. Just a guess but it doesn't care if its more or less air its out of its range.) P0272 INJ Cylinder #4 contribution/balance Power cylinder, valve train or injector (not sure whats going on there) P0480 VFAN Fan 1 control circuit Short to voltage, short to ground, open circuit (probably wiring issue check all connections for the fan) P0528 FSS Fan speed sensor circuit no signal Mechanical failure, short to voltage, open circuit, short to ground (again check everything) I would just check all your wiring connections for the fan or clear them and read again just to make sure it wasn't a fluke. The injector one not sure maybe someone can chime in here but from what I understand if you clear it and it comes back it could be on its way out. Hope that helps. Congrats on the price of that too sheesh thats a great deal. |
And could either of the fan codes be caused by the removal of the EGR throttle plate between the intake manifold and the elbow? |
No I wouldn't think so at all. From what I understand about the EGR throttle (butterfly valve) it just helps the EGR system. But since its removed you may have bumped or broke a wiring harness and not realized it. I would just look around real good. Maybe someone else can chime in because the only time I have seen this (friends truck) plug was broke. This is assuming your EGR valve is unplugged and your tunes turn the EGR system off. If not plug the valve back in and rescan. As far as injector eating issues if your eating alot and you have 5w-40 syn and 65psi pressure. I would say fuel quality and previous ownership are your biggest culprit. Last edited by FordWake; 05-02-2011 at 12:12 PM. |
I'm pretty sure the substitute for my diesel mechanic did this. It was not like this before my last injector was replaced. He also filled my coolant bottle to the brim. ![]() ![]() I've owned the truck for the last 90,000 miles of it's short (134,000 miles) life, but fuel quality here is pretty crappy. I change fuel filters every 10k though. |
I am now that my extedned warranty is out.
If you are worried about it hook it up to a real scan tool. Edge, Bullydog, Banks... All are not accurate.
Yeah I would think that was it.. ![]() as far as your injectors.. Do you run additive? If you don't that would be a big help. I run diesel clean, and FPPF. |
