6.4 Bajon Bolt ?? - Ford Powerstroke Diesel Forum
Old 05-02-2011, 09:46 AM
Illiana Chapter Director
6.4 Banjo Bolt ??
I'm installing the 6.4 banjo bolts. Got the drivers side in with no issues. Putting the passenger side in, I dropped one of the new washers and can't find it for the life of me. Will it be ok to use one of the old ones or should I go order another package of 4?
Old 05-02-2011, 09:50 AM
information regurgitator
If you have to get it going today, I would put an old one on with a prayer, and order a new pair.
Old 05-02-2011, 10:05 AM
It doesn't have to go today. It's down for coolant flush, coolant filter, full EGR delete, banjos and fuel pressure regulator upgrade. I just went ahead and ordered more washers.
Old 05-02-2011, 10:14 AM
You'll be fine, just check for leaks when you're done. Torque the cooper ones to 20 ft lbs i believe and the composite ones to 32 ft lbs.
Old 05-02-2011, 10:35 AM
I'm pretty leary about reusing one. I don't wanna have to do it again.
Old 05-02-2011, 10:39 AM
I did the same thing, and reused an old one. Haven't had any issues.
Old 05-02-2011, 02:50 PM
Break the bank and buy new.
Old 05-02-2011, 02:55 PM
Already ordered.
Old 05-02-2011, 02:58 PM
did you go copper or composite?
Old 05-02-2011, 03:04 PM
Composite, since the drivers side is already done and one is on the passenger side already.
