Stock mpg vs custom tune mpg - Ford Powerstroke Diesel Forum
Old 05-01-2011, 12:21 PM
I'm doing an experiment om my truck trying to figure which mpg I get and so far I'm getting way better mpg on my stock tune. 13mpg in town whereas on my custom Eco tune I get 11mpg in town. Why is that? I've read and heard that you get better mpg with programmers/chips on a diesel truck but I'm not. And I'm using the same driving conditions. Thanks
Old 05-01-2011, 01:00 PM
The Silent Service
You're using the wrong tunes. Most experience the mpg gains on the high HP tunes, and keeping out of the throttle. I averaged 13.3 gal on stock tuning, with the Street tune I run its 14.6. I think if you run the performance tune, you'll see what your looking for.
Old 05-01-2011, 01:10 PM
I can either run the innovative race tune or the performance tune or the Eco tune, Ill still get 11. I just can't get above 12 for some reason. My boss has the same tune but his is a 2006 and he gets 12.5-13mpg in town.
Old 05-01-2011, 05:16 PM
Mine does better around town with the stock tuning, but once I get on the freeway the higher the hp the better the mpg. Especially in hilly terrain or with strong winds. The higher power doesn't seem to work as hard.
Old 05-01-2011, 07:32 PM
Makes sense on the power and all. I wonder what kind of mpg I'll get towing a boat and a travel trailer on stick mode?
Old 05-01-2011, 09:02 PM
Then why do they all make a tune called "ECO".
Old 05-02-2011, 03:44 AM
The Silent Service
Marketing... The economy tunes all have less HP than the performance tunes, and less fueling comparitively. They therefore are also safer than a performance tune. But all the research I've done, and what I'm seeing with my proformance tune, shows me the high HP tune with a disiplined foot is the way to go.
In town, I still get better mileage tuned. But all lot of it is how you drive, I stay under 2200 rpm and 8 lbs of boost. Anything over that and I start to suffer in city.
On Edit:
Here's what I've seen with my IDP tunes: (all the same route and driving habits as possible, 65/35 highway/city combined.)
Stock - 13.3 MPG
IDP - Street - 14.6 MPG
IDP - XRace - 15.3 MPG
Last edited by colo_dually; 05-07-2011 at 05:11 PM. Reason: Follow-up for the mileage I'm seeing with my IDP tunes.
Old 05-02-2011, 06:18 AM
Then would it not be better to use a high hp tune and cut the throttle map in half, adjust the trans and call that an eco tune?
Old 05-02-2011, 01:27 PM
On the hwy with a race tune empty with no wind nothing, cruise on 70, I get 15mpg. Which I think is way to low.
Old 05-02-2011, 03:07 PM
I get better mileage running Matt's 8k tow tune than I do running his SRL tune. I drive both of them the same way but for some reason my truck likes the tow tune better.
