AirDog II install questions
When dealing with the factory for fuel lines that need to be removed for the install of the airdog lines, are there any special tools needed for dissassembly. I am getting the "quick dissconnect" version. I am installing it tuesday and would like to be as ready as possible. If you have any other advice for the install, that would be greatly appreciated.
ford fuel line quick disconnect tool at autoparts store for $5
Yup, what jetjock said. And you only need that for 1 connection IIRC.
Thank you both. looking and the directions there are 4 oem connections that need to be disconnected. The tool was 7 for a kit wtih 5 different sizes, or 30 for a nice aluminum one. im starting with the 7 and hope it works
I was able to get it all installed today, was pretty easy except for stupid things i did.
I am going back in tomorrow to finish getting it cleaned up and finished. had to get the coolant flust done today. Only had problems with the high pressure line leaving the pump not coming off, had to modify my tool to get it off, but there were 5 connections to remove, but only 2 need special tools. Now for the oil cooler tomorrow.
