Hi, new to forum, new to the 6.0, have ???'s - Ford Powerstroke Diesel Forum
Old 04-29-2011, 01:14 PM
Hi new to the forum, just recently bought a 06 FX4 Lariat Crew Cab with 61,ooo miles. I'm trying to figure out how heathly the engine is. I've been reading on the forums a far bit the last couple of weeks, and I read something about the coolant level in the tank should only be at the min. mark is that correct? Mine was fuller than the max. mark an some seemed to puke out, now it is halfway between the marks and seems to have stopped. It is the ford coolantand looks to be clean, but I don't know if it has been changed or flushed out.
If I did the flush with the restore will that clean out the oil cooler ports if they are starting to plug and by adding the coolant filter will that help with eventually flushing the cooler out?
I understand that I will need to get a Edge Insight, but I am not sure where you can get them, do auto parts stores carry them or is it only available on-line?
I bought the truck in Florida and brought it to Ontario, ran the VIN # at the local Ford dealer and no engine warranty work was done , but it had a trans. job done at 35,000 miles. Good or bad I own it now!
I would like to know if alot of the products that is talked about on the forum is readily available in Canada or under different trade names?
Sorry for all the questions, just don't know where to start, TIA.
Old 04-29-2011, 01:22 PM
The Edge Insight can be bought from many different vendors on the sight just go down to the vendor section or maybe one will chime in on here. There are several different threads on the org about the coolant flush and what it does versus what can happen just use the search function at the top of the page to find them. I haven't done it yet so I cant really tell you much about it but welcome to the org this place is great everyone is very helpful.
Old 04-29-2011, 01:45 PM
i bought my truck and the coolant level was the same deal. Keep an eye on it, i feel the dealer i bought mine from pulled a fast one, filled the level of coolant to mask the real problem of a blowen oil/egr cooler. Long story short, if the coolant level drops fast get ready to tear into her for the coolers.
Old 04-29-2011, 06:21 PM
Did you do the coolers yourself? Was it a big job?
Old 04-30-2011, 05:02 AM
First off.....WELCOME to the forum! You'll find a tremendous amount of help/feedback on this forum.
Secondly, I would first suggest investing in a monitoring system like an Edge Insight. This will provide you the data points necessary for you to determine if you have or are approaching issues/concerns such as large deltas between ECT and EOT. Without a clear way to tell, you are just stabbing in the dark.
Now....there is lots of talk about EGR and Oil coolers, ELC, etc, etc, etc on this forum. Personally, I wouldn't replace the coolant on a truck until I have data points from a monitoring system first. Reason being, if you replace the coolant (even with flushes) you may find yourself having to replace the coolers and thereby possibly flushing your money on ELC down the drain and having to do it again after the coolers are replaced.
That said, get a monitoring system quickly, monitor key items (e.g. ECT, EOT, Tran temp, etc) and soon you'll know your next steps (e.g. ELC, replacing coolers, etc).
Oh...and of course, regular maintenance on the other critical items like oil, etc.
Good luck!
Old 04-30-2011, 05:56 AM
The Silent Service
Howdy, and welcome to the ORG, and to the 6.0L family of owners.
Coolant level should be at minimum on the degas bottle, still shouldn't puke, but its something to keep an eye on. The flush with Restore will help with the Oil Cooler if its clogging up, but its not a guarantee. The only way to get everything out of there is to replace the oil cooler itself. The coolant filter won't really filter out silicate deposits, which is what clogs the oil cooler, but it will trap the casting sediment from the block.
The Edge insight is primarily found on-line, I don't know of any auto shops that stock it in stores. Make sure you buy the CS, or CTS as the original versions are no longer being updated by edge for new expansions and PIDs.
Old 04-30-2011, 09:24 AM
A flush with restore WILL NOT clear a clogged oil cooler. If in doubt, replace it so you know you have a good cooler to begin with.
Old 04-30-2011, 03:51 PM
thanks for the replies. I read about how there could be silicant build up in the cooler, wouldn't a flush wash that out, was thinking that since I don't know when the coolant was last changed it would be a good idea to flush and change it out.
Old 04-30-2011, 08:15 PM
The Restore cleaner needs to be able to flow through the oil cooler to cleaner out. If it is clogged the restore can't clean it out. If is moderately clogged it could go either way. If in doubt replace it so you KNOW what you have.
Old 04-30-2011, 10:03 PM
If you want to see how healthy the engine is...
1) How is it on start up? Does it smoke?
2) How is the all the filters?
3) how are all the fluids?
4)Are there and signs of rough startup? breaking up or lack of power under acceleration? Heavy smoking? Drinking coolant? burning oil?
5) Gauges will tell you A LOT about the temps inside the engine which can help you pin point an issue.
6) is this a work/tow/play rig??
