Originally Posted by strokin6L
so is your dakota digital HPOP gauge reading in psi or voltage? Also is the harness a plug and play harness or did you actually have to tap into a wire off the harness for the ICP sensor? Do you have any pics of the gauges installed and displaying readings. After reading the egt instructions...seems like it'll take some getting use to seeing as that it only reads three digits. Examples are...06 is 60*, 70 is 700*, and 120 would be 1200*.
It reads in PSI. The analog gauge I sent down to DD came with an optional pigtail which had an extra wire sticking out of it to connect your gauge to, so yes plug & play. It is so simple though to strip a little insulation off the OEM wiring to connect your gauge, but if you want plug & play just phone a place that sells an analog HPOP gauge and order just the pigtail as it was like a $10 or $15 option when I ordered mine. Some places may say "no" but tell them "the dealer mechanic screwed your pigtail up and you need a new one". They may feel sorry for you and agree to send you a pigtail. LOL
As for the EGT, you just lose the forth digit when the temperature is 1000 degrees and hotter. eg: 950 degrees displays as "950" but 1145 would display as "114". Really though, how often are you running 1000 degrees or hotter and if you are you are surely going to know when you are pulling a heavy load up a long hill that a displayed reading of 120 is "1200" and NOT indicating a temperature of 120?
Next days off I will post some pics.
