ARP torque spec - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-28-2011, 08:16 PM Thread Starter
BigBear713's Avatar
ARP torque spec
I have read the sticky for the new "recommendations" for torquing the head studs in. I see that it says follow fords torque sequence but it says do it in three steps ending with 210 ft lbs. My question is that have any of you guys followed this procedure before? Or should I just follow the old procedure ending in 245 ft lbs?
2003 f350
SRW
CC
EDGE INSIGHT CTS
EGR DELETE
ARP'S
BLACK ONYX
POWERMAX
ACCUFAB POWER ELBOW
MAGNAFLOW TURBO BACK
AFE STAGE 2 COLD AIR
6.4 BANJO'S
BLUE SPRING
UPDATED OIL FEED AND DRAIN
4 INCH PRO COMP LIFT
DUAL STEERING STABILIZERS
DUAL FRONT SHOCKS
35 BFG KM2 ON 18 INCUBUS
BigBear713 is offline
post #2 of 3 Old 04-28-2011, 08:56 PM
rem1981's Avatar
What they mean is follow the Ford torque sequence, but stop at 210 ft lbs. These are the new instructions from ARP. They changed their thread lube, so now they say 210. However, if you buy a new set of ARPs but they are old stock, it may still come with the old lube, and the instructions may still say 245 or whatever. Basically, follow the ARP instructions. They know best.
I dream of a better tomorrow, where chickens can cross the road and not be questioned about their motives.
rem1981 is offline
post #3 of 3 Old 04-29-2011, 09:57 AM Thread Starter
BigBear713's Avatar
Okay Thanks.
2003 f350
SRW
CC
EDGE INSIGHT CTS
EGR DELETE
ARP'S
BLACK ONYX
POWERMAX
ACCUFAB POWER ELBOW
6.4 BANJO'S
BLUE SPRING
DUAL FRONT SHOCKS
