antifreeze coming out degas - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-28-2011, 03:41 PM Thread Starter
What does it mean when I have antifreeze coming out the degas jug
05 F350 SC FX4 sortbox
DYI coolant filter
4 turbo back
AFE stage 1 air fliter
SCT sf3
edge insight CTS
owenkicker is offline
post #2 of 10 Old 04-28-2011, 04:08 PM
taskforcefreddy's Avatar
Usually bad things bud. Could be head gaskets or a bad EGR cooler which may have been caused by a clogged oil cooler. Do some searching on here and you will see the other indicators to look for to help narrow down the culprit.
taskforcefreddy is offline
post #3 of 10 Old 04-28-2011, 04:13 PM
bwillis2003's Avatar
Originally Posted by taskforcefreddy View Post
Usually bad things bud. Could be head gaskets or a bad EGR cooler which made have been caused by a clogged oil cooler. Do some searching on here and you will see the other indecators to looks for to help narrow down the culprit.
I agree. I had a bad EGR cooler. Built so much pressure that coolant was comin out of the bottle some. Got an EGR delete a couple weeks ago, problem solved. Another thing is, turn off your radio, roll windows up, get up to like 75 mph, and then let off the gas, you will probably hear a tea kettle sound. EGR delete shouild fix this too.
You could have blown your gaskets too. If you cooler is bad, replace immediately. If you dont, you can blow your headgaskets. At that point in time, you have a very expensive couple of fixes. Dont wait.
Brandon
2007 F-250 6 point oh
146,000 miles
2.5 inch BDS leveling kit
35" Toyo Open Country A/T
OEM rotors w/ Hawk LTS pads
5 inch custom sidepipe
Edge Insight CTS
SCT X3 w/ Innovative Tunes
ARP headstuds
Bilstein 5100s
Banjo Bolts
NCHornet's CCV Mod
Dieselsite Boots
EGR Delete
FICM fixed by Ed/tuned by PHP
S&B Intake
Dfuser Coolant Filter Kit
2003 F-250 7.3
84,000 miles
SOLD
bwillis2003 is offline
post #4 of 10 Old 04-28-2011, 04:19 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Failed HG, failed EGR cooler, blocked up oil cooler that caused the EGR cooler to fail, weak degas bottle cap, overfilled degas bottle.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 10 Old 04-28-2011, 04:28 PM Thread Starter
i've had the tea kettle sound for about 2 weeks. i called local shop which is reputable
he said i had a crack in some pipe. said it's not a big deal until i lose my boost
DYI coolant filter
4 turbo back
SCT sf3
edge insight CTS
post #6 of 10 Old 04-28-2011, 04:28 PM
rem1981's Avatar
It means your wallet is about to take a beating. Sorry, dude. I feel your pain.
I dream of a better tomorrow, where chickens can cross the road and not be questioned about their motives.
rem1981 is offline
post #7 of 10 Old 04-28-2011, 06:24 PM Thread Starter
anybody have a good delete system recommendations
also is there a way to clean out a oil cooler or do i have to get a new one? or should i just start with doing the delete. and see what happen from there
DYI coolant filter
4 turbo back
SCT sf3
edge insight CTS
post #8 of 10 Old 04-28-2011, 06:24 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Read the first link in my signature. It'll explain a lot.
If you didn't replace your oil cooler at the same time you should have. It is SOP for a ruptured egr cooler. What is your ECT/EOT delta? If you don't know you're playing Russian Roulette.
RIP Mitch
the Org crew
PGreenSVT is offline
post #9 of 10 Old 04-29-2011, 03:59 PM
Its usually within 2 of each other..as much as 9, only for a short period of time. Hopefully im okay..may end up replacing it eventually.
Brandon
146,000 miles
Edge Insight CTS
ARP headstuds
Bilstein 5100s
Banjo Bolts
NCHornet's CCV Mod
Dieselsite Boots
EGR Delete
S&B Intake
2003 F-250 7.3
84,000 miles
SOLD
post #10 of 10 Old 04-29-2011, 03:59 PM
I have a suggestion for one. PM me.
Brandon
146,000 miles
Edge Insight CTS
ARP headstuds
Bilstein 5100s
Banjo Bolts
NCHornet's CCV Mod
Dieselsite Boots
EGR Delete
S&B Intake
2003 F-250 7.3
84,000 miles
SOLD
