Tinny bit of "bucking"
I had a small load (2000 max) on the back of my truck a bit ago. When going up a hill about 50 or so, I wasnt into it enough to kick down but it was at a low rpm with good boost....I had a little bit of bucking.
Anyone have this? Normal? It went away when it kicked down. |
I had that happen a couple times late last fall/early winter when my engine was cold. Shortly thereafter I had 4 injectors replaced and the computer reflashed for my really bad stiction problem. Never saw the problem again. I'm not sure why that cured it but it did. Hopefully that isn't the actual cure for it.
I should have thought before I posted! lol |
Injector(s) or TC slipping. Check your trans fluid level
I agree, TC issue sounds like.
yeah, I have had the same thing happen, its the TC slipping from you getting in it at too low of an RPM and it not shifting right away. adjust right foot position and problem solved!
i have a similar issue in my truck but in second and third under accel with converter locked. my bucking is coming from the fact that i don't have traction bars and i have horible axle wrap. but it only bucks when towing not sure if maybe you are having any bit of the same thing happening to you.
You can say it is your right foot all you want to, but it is not. You have a issue somewhere. Check your trans fluid.
![]() I do apprecate the help though! Last edited by Galaxie; 04-29-2011 at 05:15 AM. |
