Need some advice for coolant flush
So i know there are a few of these already but i wanted to put my questions in to get it direct.
Is it very difficult to do? -I understand it is easy to do but do i read somewhere some guys were driving around for an hour with the distilled water then flush and do this 4 or 5 times, is this necessary? What are the additives that you use? -VC-9? I think thats what its called and Restore? What do these do and why do we use them, and also where can you buy these and once again are these necessary? How long does the entire process take? Also i think im going to buy the sinister filter kit, are these any good? once again are these necessary? I just bought the truck and im just a little nervous and dont want to mess anything up; thanks guys |
Here is the procedure I use that a bunch of folks use as well. Flushing and cleaning the 6.0 Restore is for cleaning out any silicate goo. VC-9 is for cleaning out iron and scale. Restore Plus is the same as VC-9 and cheaper. To flush drain the coolant by removing the lower radiator hose from the radiator, and removing the drain plug from the driver side of the block. There is a drain plug on the passenger side also but you have to remove the starter to get to it. I don't bother with that one. You can skip the block drains if you want except for the final drain before adding fresh coolant. You will just have to flush a few more times to get the block clear. I also highly recommend you pull the thermostat out on your first drain and put the housing back without the thermostat. It only takes about 10 minutes and will save you 2.5 hrs or so in doing this whole procedure. Ok now put the lower hose back on and the drain plug back in the block if you removed it. This is the procedure you will use each time to drain the system, except you will not touch the thermostat again until you're finished the whole procedure. Make sure that you set your heater to high while doing this to flush out the heater core as well. Fill the cooling system with tap water, start the truck and let the water circulate for 5 minutes. (if you did not remove the thermostat you must run the truck until the thermostat opens + 5 minutes to circulate. This takes 15 to 20 minutes each cycle and is why you should just remove the thermostat) Stop the engine. Drain the system and repeat the flush. Now add at least 1/2 gallon of Restore and fill with water. Drive truck or run on high idle for 60-90 minutes. Drain and flush 3 or 4 times. Add 2qts VC-9 or 1/2gal of Restore Plus, top with water, and drive the truck or run on high idle for 60-90 minutes. Now drain and flush until flush water comes out clear and clean. When you get clean flush water, flush 3 more times using distilled water if you are draining the block or 5 times if not. This is to replace any tap water in the cooling system with distilled water and very important. After your final distilled water drain it is time to put the thermostat back in. I recommend you install a new thermostat at this point. They are only $20 or so and it is good maintenance procedure to do so. Fill with 3.5 or 4 gals of ELC concentrated coolant and top off with distilled water. Drive the truck or let run for a while topping off with distilled water. Check the truck over the next few days and top up as required while any air left in the system works its way out. Keep some 50/50 ELC on hand to use to top off the cooling system from here out and you are good to go. Hope this helps. Mitch |
07, Mitch is right and has it down to a science. The only thing I have to add is make sure you spend alot of time reading through the info on this site. Theres alot of BS to sift through but all the info you need is here. Good luck!
Super easy! Just takes time. That is the crappy part! I would rather something that was really hard but only took 30 minutes. This is as easy as it comes but takes hours!
Okay...
I have a question along these lines as I'm about to switch from gold to ELC and go with a filter kit as well... Where do you catch all the drainage? I only have a 15qt pan and this is going to put out many gallons of drainage... Need I invest in a 25gal drum? -Ed |
I have about 8 five gallon pails with lids that I use for jobs like this. They are old foam concentrate containers from a fire department and have 2" caps on the lid I can pour from. I use them for oil and coolant. It allows me the room I need to dump...yet makes them easy to transport to the recycle location for disposal. If you use a larger container...you'll not be able to lift it or pour it well. It'll take a fork lift to get it outta your garage.
My main question about this flush on 6.0L's is simple but very important: Does the flush process remove/dissolve any solid or goo that is the cause of oil coolers plugging? Or is it true that once the cooler is blocked up...NOTHING will help it? The Ford dealership here says that once its clogged....its over. Anybody ever inspected an oil cooler suspected to be clogged (temp diff) and then looked at it after a flush? Ford had some that were so clogged...hooking up a garden hose to them would barely flow anything thru it...while a new one passed the water fully. They demonstrated it to me in person. I mentioned this flush process and they said they knew of it...but when I mentioned the chemicals and steps involved...the conversation kinda went quiet. Last edited by neil; 04-29-2011 at 03:48 PM. |
If my coolers are good (new, shop didn't flush like I asked them to so now its up to me) should you still use restore and restore plus? Would that not be asking for trouble by breaking that goo and other stuff loose for it to be sent into oil cooler?
Not to hijack but I have one question that I can't find an answer for. When you refill with water between flushes are you putting cold water in a hot engine or letting the truck cool for a while? Thanks.
By the 6th dump of distilled water, the engine was getting toasty....to the point that pulling the rear block plug caused some pretty hot water to dump down my hand/arm. Thank goodness for a creeper with wheels that allowed for some quick rolling! And by the 6th dump, the water was crystal clear. |
Last summer, Ford replaced my EGR and Oil coolers (to the tune of $1800) and I put on about 3k miles between then and when I did my flush and ELC change over. Fortunately, my system looked good from a rust/scale perspective to start with so although I did both Restore and Restore Plus, most of the emphasis was on the Restore side to remove the silicates. But, I've been also using a coolant filter for a few years too. |
