Dead battery - cannot unlock truck - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 41 Old 04-26-2011, 02:17 PM Thread Starter
Hey,
So I had two week vacation, came home, and I cannot unlock the doors on my truck cause the batteries are dead.
Question is: How the hell do I open the doors?
2006 Ford F-350 King Ranch 6.0 Powerstoke
ARP Headstuds
SCT X3 w/xtreme street from Innovative Diesel
Blows your mind drastically, fantastically - With diesel power!
magnus is offline
post #2 of 41 Old 04-26-2011, 02:23 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Originally Posted by magnus View Post
Hey,
Where are the keys, locked in the truck? Go to your local dealership with the VIN# and proof of ownership and they can cut you a key.
dhanna6powerstroke is offline
post #3 of 41 Old 04-26-2011, 02:24 PM
01powestroke's Avatar
did you put back handles on the front of the truck? if not the key should open it
2001 f250 lariat 7.3 3.73 rear end 4" exaust with muffler-5"tip eagle alloy rims with 305/70 firesteone at, superchips programmer
2002 dodge durango slt+ 4.7v8 flowmaster super 10, intake, ho cams ,superchips programmer, trying to trade it for a diesel
01powestroke is offline
post #4 of 41 Old 04-26-2011, 02:30 PM Thread Starter
I have the keys, when I insert them, I cannot turn them for whatever reason.
01powerstroke - you lost me on what you said?
ARP Headstuds
magnus is offline
post #5 of 41 Old 04-26-2011, 02:35 PM
Mod Newbie
Quoted: 20 Post(s)
Some guys put the doors handles that are on the rear doors of a crew cab on the fron doors so people can't knock the key cylinder out and break into it.
Can't turn the locks on either front door? There shouldn't be anything keeping it from turning. I'm not trying to be a smarta**, but you do have he correct key don't you? I've done that before.
jokester00 likes this.
post #6 of 41 Old 04-26-2011, 02:44 PM
I have sat there pissed I could not get into my truck with my mustang keys... to the point of calling a locksmith before I realized what a dumb**** i was.
2006 F250 FX4 Crew Cab - ARP Studs, EGR Delete, Edge Insight w/pyro, SCT X3 with SRL+
2005 Mustang GT - slightly modded
1986 F250 IDI 4x4 ZF5 - Sold
1979 Bronco 460
1967 M35A2 Deuce w/winch FOR SALE!!!
emperorjordan is offline
post #7 of 41 Old 04-26-2011, 02:47 PM
Mod Newbie
Quoted: 20 Post(s)
Exactly why I mentioned that.
post #8 of 41 Old 04-26-2011, 03:08 PM
mah77's Avatar
I thought maybe you were trying to get into someone else's truck. Whether by mistake or on purpose.
06 F250 FX4 Lariat, 35" Nitto Terra Grapplers, 6" Lift Leveled w/Bilsteins, 4" MBRP TB Exhaust w/Cat Delete, Edge Insight w/EGT Probe & Dash Pod, SCT X3 w/SRL Tune From Matt @ Gearhead, Powerslot Rotors, Hawk Pads, Upgraded Oil Cooler Screen, Upgraded Turbo Drain Tube, Upgraded STC Fitting, Upgraded FPR Spring, CAT ELC Coolant, ARP Head Studs, Opti-Lube XPD, Coolant Filter, 45K Miles
mah77 is offline
post #9 of 41 Old 04-26-2011, 03:18 PM
thats not as bad as trying to use a key from a dodge durango to start it and not realize it
post #10 of 41 Old 04-26-2011, 03:25 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
What about using your hitch electrical connector, and make it so you can put power from the connector on the truck to a spare battery or jumper vehicle. It might give you enough juice to activate the locks.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
