Diesel Site Coolant Filter - Filter Change
I just did a flush, loaded up with cherry coolaid (ELC). Anyway, when should I change that first filter out?
I put about 100 miles on her with a decent load since the flush, still looking like new! I had to go back and tighten the clamps after a few heat cycles but all is good! Thanks, Colin |
I believe it's 500 miles for the first one, then 1000 miles on the second and then yearly after that.
But I'm going to change them at 500 for the first, 500 for the second, 1000 for the third and then yearly |
Awesome. Thanks Dz4!
No prob bro
Just ordered the same system. Here is what the site says:
Use one filter every three months for the first nine months after installation. The lack of flow into the expansion tank is an indication that your filter is plugged. Change the filter if it should plug before the 3-month interval. After the 4th filter is installed your filter should be changed once per year. Hope that is helpful. |
Before somebody asks what filters to use. Here are the filters that fit.
COOLANT FILTERS Fleetguard WF-2077 Baldwin B5134 John Deere RE11992 Caterpillar 9Y4528 Cummins 3300721 Wix 24070 NAPA 4070 AC-Delco WF-108 Fram PR3383 Donaldson P554685 Alliance (Freightliner) WF2077 CarQuest 89070 |
im thinkin the Dieselsite Coolant Filter...!!!
OP, did you go through the restore process or just straight water flushes, then to ELC?
COOLANT FILTERS Fleetguard WF-2077 yes Baldwin B5134 yes John Deere RE11992 yes Caterpillar 9Y4528 yes Cummins 3300721 yes Wix 24070 yes and 27 micron NAPA 4070 Yes and 27 micron AC-Delco WF-108 can't find any info other than it cross-references Fram PR3383 can't find any info other than it cross-references Donaldson P554685 /ECF4085 Yes 14 micron edited per post from txgp17 Alliance (Freightliner) WF2077 can't find any info other than it cross-references CarQuest 89070 can't find any info other than it cross-references size specs Thread Size: 11/16-16 Outer Diameter: 3.66" (93 mm) Gasket OD: 2.81" (71 mm) Gasket ID: 2.42" (61 mm) Last edited by rentstdi; 01-23-2012 at 06:39 PM. |
