Coolant flush and coolant filter install - Ford Powerstroke Diesel Forum
Old 04-24-2011, 07:46 AM
I am planning on doing the coolant flush in the fairly near future. I would like to add a coolant filter, too. My question is, would it be helpful (or wise) to install the filter before doing the flush? I was thinking that running the filter for a few weeks, keep changing it as necessary, would help with the flush when I get around to it. Or would that just be a waste of several filters?
On a related note, I am thinking of changing the oil cooler at the same time. Should I flush before changing the cooler? It would seem to be a waste of time to flush after changing it, all the crud would just re-settle in there, right?
TIA
George
Old 04-24-2011, 08:03 AM
back to business
Flush before adding the filter and before replacing oil cooler.
Old 04-24-2011, 08:16 AM
Yup. Do your flush first, then change the cooler add the filter and fill'er up with coolant.
Old 04-24-2011, 08:32 AM
NOT a Democrat
Do you need an oil cooler? I did my flush yesterday and then did my filter.
All the flushes took about 5 hours (even with pulling the stat). The coolant filter took about 15 minutes.
Old 04-24-2011, 08:52 AM
Not sure. According to my Scangauge, the cooler seems to be ok, now. I am going to do the coolant flush/filter first and see how things go. I hope the cooler is ok after the flushing, keeping fingers crossed!
Old 04-24-2011, 09:10 AM
What are your temps now, before flushing?
Old 04-24-2011, 09:18 AM
At a steady 65, ambient of around 50F, empty truck, the ECT shows 181-182, think I need to change the tstat, and the EOT is around 190.
Old 04-24-2011, 09:27 AM
That's the same delta I have. Only difference is, my temps are running 10°higher than yours. My ECT is running 190-192 and EOT is 200-202.
Old 04-24-2011, 11:15 AM
I figured since I'm going to do the coolant flush, and the tstat should be removed to do this, just as soon put in a new one, peace of mind sort of thing. Based on the great how-to by PGreen.
Old 04-26-2011, 01:00 PM
Just curious, why would flushing after adding coolant filter not be a good idea?
