Cat ELC price - Ford Powerstroke Diesel Forum
Old 04-23-2011, 09:52 PM
Cat ELC price
Ok so i went to my Catapillar dealer to pick up some coolant because im going to do the switch and i asked them if they had any and they dident. So im having them get me 7 gallons of 50/50 and they said it was only like $11 and some change. Is that right? It seems like everyone else has said about like $20 or so. And they said it was orange is all this right? I just want to make sure before i buy the wrong stuff
Thanks in advance!
Old 04-24-2011, 04:41 AM
I too went to the CAT dealer and they only have 50/50 of the EC-1. And was advised they couldn't get the EC-1 Concentrate. So I purchased Zerex ELC EC-1 from NAPA for about $20 a gallon.
My concern for you with using the 50/50 mixture is that because you won't be able to get all the water out, you'll actually have a less than 50/50 mixture - - it'll be too diluted. So my suggestion, if you can, cancel the CAT 50/50 and get the Zerex ELC EC-1 Concentrate. Then dump 3.5 to 4 gallons in and top off with distilled.
Old 04-24-2011, 05:52 AM
NOT a Democrat
Yea, super hard to get all of the water out. I would get at least a few gallons of stright concentrate. Will be about $20 each at least. I ran 2 gallons of stright and fished it off with 50/50. I am just about a perfect 50/50 per the strip!
Old 04-24-2011, 05:58 AM
it should run about $25 a gallon for concentrate. The model number used to be 119-5250 i believe. Now it's 238-8647...$11 a gallon is prob Cat Deac or w/e its called.
Old 04-24-2011, 06:51 AM
at my HO Penn dealer concentrate is $18 a gallon and 50/50 is $15 a gallon
Old 04-24-2011, 06:58 AM
I picked up four 1USG jugs of Chevron Delo concentrate yesterday at my local International dealer for $11.85 each.
Old 04-24-2011, 07:03 AM
I bought 4 gal yesterday from a freightliner dealer at a discount price of 23 dollars and some change. Expensive stuff!
Old 04-24-2011, 09:58 AM
Ok so would any orange ELC coolant work i just don want to get the wrong stuff you knw.
Old 04-24-2011, 10:19 AM
The orange is usually for GM trucks. Ford also has a Orange one that they put in the new 2011 Superduty, but I wouldnt try and risk puttin it in the older ones.
Rotella has a relatively new Ultra ELC which can be used in all types of cars and trucks, diesel and gassers alike, but it is not available in anything smaller than a 55 gallon drum, yet. Alteast, thats what ive heard.
Old 04-25-2011, 04:15 PM
So what color is the ELC coolant I need to know the exact stuff because Iam about to do all my Egr delete and everything.
Thanks in advance!
