oil cooler replacement
i am replacing my oil cooler and egr and have gotten to the point of taking the oil cooler housing off but wondering if the coolant will flood the oil cooler housing and get into the oil. is it required to drain the block before removing the cooler? to this point of taking everything apart i havent really had any coolant leak out but can see is in the housing where it fills the oil cooler
no,no coolant will mix.of course when i do these installs i change oil and coolant..if coolant is not the elc stuff...yank her out dude.your good
so without draining the system i will still be fine?
yep, no worries
so i finally got everything taken apart and ready for tomorrow to put my new oil cooler in and and egr delete. i know i isnt good to get coolant in with the oil but if some does what would but a level to be worried with? id say in total their may of been less then a 1/4 cup and i think i got most of it out right away.
Of course you drop the coolant to do an oil cooler r&r. You have to pull the intake do you not? That reservoir goes straight to the hpop so it will already be too late if you flooded it with coolant for an oil change to save you. You should remove the oil there anyways and replace the screen.
