Wierd shift 2-3 - Ford Powerstroke Diesel Forum
Old 04-23-2011, 01:47 PM
Wierd shift 2-3
Yesterday I had got into it about 3/4-7/8 throttle and when it tried to shift to 3 it just about felt like it went into neutral. I let out of it because it hit rev limit. I am running srl+. I have never had any problems with my transmission shifting at all. I do have a small pause when shifting into drive or reverse but never had any issues when going down the road. Anyone have any ideas?
Old 04-25-2011, 05:00 AM
I ordered gogodiesels direct clutch soleniod and a new epc soleniod for the tranny. Has anyone had this problem and do they think that this will help?
Old 04-25-2011, 05:37 AM
Was your tranny warmed up when this happened?
Old 04-25-2011, 05:47 AM
Yes it was completly warmed up. And the more I think about it now I think it was when it shifted out of 3rd. It happened so fast and freaked me out so much I think I might have been wrong on the gear at first. I have not been able to recreate the problem so I can not be sure. I also get a small shutter when I go into reverse and give it some pedal from time to time.
Old 04-25-2011, 06:19 AM
Transgo shift kit fixes the shift issues. I plan on getting it over the summer when I have time to work on it.
Old 04-25-2011, 07:10 AM
Will that help my shift out of 3rd? seems like its more for just reverse and at a stop. plus my year shouldnt have the problem with the c clip coming out should it? From what Iv read thats just with 05 and later
Old 04-25-2011, 07:21 AM
Slacker
Feedback Score: 4 reviews
Pretty sure that the c-clip was a 2004 issue with the 5R110. Not sure if that's your issue, though.
Old 04-25-2011, 07:23 AM
Mine is a early build 04 I think the problem started in late 04. I may be wrong though.
Old 04-25-2011, 07:27 AM
Slacker
From Bismic's thread on FTE.
The issue with the 04's involved replacement of the reverse planet assembly due to low/reverse gear set pinion shaft(s) that may walk out. Vehicles affected were built from 03/08/04 through 06/24/04.
Old 04-25-2011, 07:28 AM
Mine was built in 2/04
