I was driving tonite, 65mph (gps), cruise on, empty truck. My Scangauge showed ECT of 181-182*F, and it dipped to about 178F for a short while. Ambient temp was about 55F or so.
Is the T-stat gone? Do I need to replace it? If so, what temp T-stat should I get? '06, Auto, 4x4 What happens if the ECT stays low? Sorry for all the questions, again, newbie here. |
Sounds like the t-stat needs replaced. Should be a 192* i think. if you get it from ford it comes with the entire housing and costs about $40.
Like cyclone said, sounds like your stat is stuck.
You will be glad to replace it and your local driving fuel mileage will improve enough to pay for the Thermostat.
Oil has to be at 180F for the turbo to stop heating the engine and the EGR valve to start closing, so the longer it takes the water to heat the oil the harder it is on fuel. |
Factory Tstat partially opens at 182. So at 50 degrees seeing 180-184 isnt out of the ordinary
Thanks for the input, guys. Just read another post pointing out the high frequency of failed oil coolers after the coolant flush and change. Should I just change the oil cooler, too or hope it doesn't happen to me? Sounds like the flush is what brings about an early demise of the oil cooler. Is Restore the Grim Reaper of oil coolers? Last edited by beemerbiker5; 04-23-2011 at 07:15 AM. |
This could be a sign of your oil cooler plugging.
