a/c mode door issue??
05 F-250 just wondering if anyone has ever had a problem with their a/c mode door, it seems like it takes alot longer than it should before it actually swithces from def and floor to vent, just on start up, i know older vehicles all that is operated by vacuum but i wasnt for sure with my new truck, aby help?!?!?!?!
Yes it is most likely a vacuum leak. The vacuum pump is on top of the right side wheel well just behind the vacuum tank so if it keeps on running then you have a leak somewhere. Most common leak area are the vacuum lines to your 4X4 front axle.
plug the outlet for your hubs at the valve, check you heater controls. If they work you have a leak in hub system.
