warm up time - Ford Powerstroke Diesel Forum
Old 04-22-2011, 05:28 PM
warm up time
How long do you guys warm up your engines? certain amount of time or certain ECT/EOT?
I usually warm mine up to about 108 degrees ECT, then take it easy til after 150 deg ECT, and never get the boost up til it's at 190 ECT. Just wondering if it's important?
Old 04-22-2011, 06:01 PM
Personally, I don't have a problem starting the truck, waiting a minute or less and then taking off slowly....not romping on it. HOWEVER, if I have to haul with it, I always let it warm up well....150+ ECT. My belief...that if you aren't going to be putting a major load on the engine, just a short idle time is fine. But anything that is going to tax (stress) the engine/tranny, I want the lubrication flowing well. And besides, the power (torque) from these diesels require heat for full combustion such as why I let her warm up well before pulling a hard load.
Old 04-22-2011, 07:59 PM
+1 .
Old 04-23-2011, 04:55 AM
I have been taking off as soon as I can shift it for the past 42 years and never saw any dirt in my engines and all my vehicles have been mostly junked after the body gets to old.
A diesel will heat up only when it is working and heating them whiile appying power from the power train is as good as sitting Idle with the turbo shut to create heat.
When I tow I just take it easy for the first mile or so till the temperature of the oil is at 160F. Oil Temperature is what is important not water temperature, but the cooler usualy keep it at 5to8F lower then the water when heating up.
Old 04-23-2011, 09:26 AM
Same here I try to let it run for 5-10 min before I leave but sometimes I cant and I just take it easy until its warmed up
Old 04-24-2011, 04:35 PM
I probably wont warm it up as long as I had been then. I know I'm wasting a lot of fuel sitting there warming up, especially when it's cold out and I'm running the high idle.
Old 04-24-2011, 05:10 PM
NOT a Democrat
I wait a good 3-5 mintues or so. If it is SUPER COLD and I am not pluged in e.g. at work in the middle of winter, i will wait 10-15 minutes. But that is my time when I can smoke a backwood and get caught up on calls after work
Old 04-24-2011, 05:16 PM
Powered by Deez Nuts
under 30secs is what i wait. then its driving time.
I let mine run for a minute or two while I get my seatbelt on and get situated then I drop it in gear and head out easy. I don't romp on it till it's up over 160*.
