Coolant filter replacement - Ford Powerstroke Diesel Forum
Old 04-22-2011, 03:37 PM
Alright, my filter is due to be swapped out, but I can not get the old one off to save my life. I even took the base out to try and get better leverage on it. Anyone else run into this problem?
Old 04-22-2011, 09:26 PM
Yep, used a vice and a pipe wrench...
Old 04-23-2011, 06:54 AM
Next time pull out your oil dipstick and lube the o-ring seal.
Old 04-23-2011, 07:53 AM
Yea or I used a little grease. Just gotta put somethin on there.
Old 04-23-2011, 08:17 AM
I use a strap wrench to get mine out. Need to do the oil trick as getting it out is still a PITA.
Old 04-23-2011, 08:50 AM
oil or grease on the o-ring of the filter...get some on your finger and wipe it on, makes things easier
Old 04-23-2011, 09:22 AM
stab a screwdriver threw it and twist messy but works
Old 04-23-2011, 12:35 PM
That'll do it!
