FICM volts - Ford Powerstroke Diesel Forum
Old 04-20-2011, 05:04 PM
FICM volts
I had 24 volts cranking cold. I soldered one loose chip. Now on my edge insight I get 36v cold cranking, then it creeps up to 48v. It will bounce around, 48,47,47.5,48,......etc. all day. Even hot starts will be 48v cranking. I check my codes daily since I soldered it in january. Maybe once a month I will get a P0611. Should I solder the other chips? Or should I leave it as-is for now
Old 04-20-2011, 05:17 PM
Illiana Chapter Director
Need to do them all before it goes completely.
Old 04-20-2011, 05:25 PM
So yank it out, do them all, should be ok for a while then?
Old 04-20-2011, 05:31 PM
Yep, will probably be just fine.
