Stoopopy Question of the day - Heated Backlight? - Ford Powerstroke Diesel Forum
Old 04-20-2011, 05:03 AM
I'm going thru my manual to determine if I have any fuse spots available and ran across a 40A Maxi Fuse and according to my manual, it is for a heated backlight. What and where is that?
Sorry for the silly question....the manual doesn't say a thing about what it is.
Old 04-20-2011, 05:18 AM
What year model? I just glanced through my '05 manual and found no such critter. Is it listed in the interior fuse panel or the high-current panel under the hood?
Old 04-20-2011, 06:03 AM
It is a 2004 F350 CC Dually. The 40A Maxi Fuse is on the inside fuse box labeled 104.
Old 04-20-2011, 08:01 AM
backlight is OEM speak for rear window IIRC
Old 04-20-2011, 10:03 AM
So my rear window is heated? Neat! Wonder how it does that....as I don't see any wires, etc in or around it nor are there any switches on the dash for it.
Old 04-20-2011, 10:35 AM
I might have been an option but not installed on your truck ?
My old chevy had a rear defrost, I miss that a ton.
Old 04-20-2011, 03:17 PM
xactly it might have never been used ,, I have a slider on my 06 my last gm truck with a 1 piece rear had a defrost maybe that is the difference?
Old 04-20-2011, 05:00 PM
Well that's good news for me then! Since I don't have a rear defroster (not that I can tell at least), having a fuse in that spot tells me the wiring is there. I can tap into that for my transfer tank pump. Life is good!
