Truck is starting to ride a bit different
First a little about the truck. 2005 Crew F250 with just under 35,000 miles.
I'm starting to notice as I am riding down the highway if I hit a bump the steering wheel starts to jump around a bit. A few times I have hit a bump with one side of the truck and the wheel shacks back and forth like 5-8 times. The entire truck shimmies while the steering wheel is shacking. I bought this truck with 27K on it and last year we drove over 1400 miles back and forth to TN and another 2000 miles back and forth to FL. I know that this is starting to get worse just have no idea what is causing it. I'm fearing that I need to start replacing parts just not sure where to start.
Sounds like your steering stabilizer is shot. The stock ones are crap.
Got mine here: http://www.shockwarehouse.com/site/search.cfm Part# F4-BE5-H086-H0
Completely stock. Basic shade tree mechanic here. I know what some of those parts are what should I be looking for?
I had the exact same problem with my truck and trust me it will get worse from there. Mine ended up being the drag link. Ebay has the ends for about 100 bucks, I would get on this sooner than later.
Replace the stabilizer, and if that doesn't fix it, start replacing other parts till you fix it.
What you got is the infamous super duty "death wobble"...its got that name for a reason. |
Heres a video of a pretty bad example:
You can see why its got its name. Hes unloaded, imagine towing a trailer in some wind and get that wheel shake going on...hello ditch. |
About 5-10 minutes. Remove two nuts.
