oil help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-18-2011, 08:34 PM Thread Starter
oil help
Hey guys, I'm new around here but I have noticed in a short time that a lot of your are running this T6 rotella 10w30 ! I have never seen any other diesel oil than 15w40(which I run now) and 0w40 !
My truck usually sees 2 oil changes a month, that's how much I'm on the road lol where can I find this T6 10w30 and is it priced much different than the 15w40 rotella I use now ? Also if it is full syn how many miles can u go on it if regular oil calls for 7500 ?
ClutchR16.0 is offline
post #2 of 8 Old 04-18-2011, 10:25 PM
Rotella T6 5w40 is a full Syn oil you can pick it up at Walmart along with your Motorcraft filter (only use motorcraft or racor filters) and the 6.0 should only go 5k on the oil because of the shear of the oil by the injectors. I use Amsoil in mine i think it is a good full Syn oil the price is high but mine pulls 95% of the time i use my 97 as a grocery getter.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 8 Old 04-19-2011, 07:07 AM
O'reily's has the T6 on sale right now for $17.99 a jug! I bought everything they had in stock so i'm good for the next 2 oil changes now.
I would suggest running this for 5k, then get an oil analysis done and see if you can go longer on it.
I've heard that the regular shell 15w-40 is hard on the 6.0 so I wont use it in my truck.
2013 Harley Davidson Street Glide, Midnight Pearl
Vance and Hines Big radius pipes
Power Commander V
Arlen Ness air cleaner
2005 F-250 SCSB Lariat FX4.
ARP Head Studs
EGR Delete
SCT X3 with IDP tunes.
Edge Insight CS w/ EGT probe
4" MBRP turbo back
Quick Tricks 58V FICM
cyclonestroker is offline
post #4 of 8 Old 04-19-2011, 07:35 AM
Chango's Avatar
thanks for the heads up! Im going to shoot over there after work
Awesome thread on oil / cold start issues for 6.0 ---->
Troubleshooting a no Start Condition --->
Still using Ford Coolant? ---->
Chango is offline
post #5 of 8 Old 04-19-2011, 05:09 PM
shiprek's Avatar
Don't want to hijack the thread but I am interested in this too. I just changed my oil and used Rotella 15w40 in anticipation of summer. I would rather run a synthetic but was hoping to find it in a 15w40 rather than a 10w30. Does such a thing exist? Thx
2004 F250 Lariat/6.0L/SRW/Crewcab/Shortbed FX4
EDGE Evolution CTS
Python 424 Remote Start
Volant Ram Air
RCD-EGR Delete
Cat/Muffler Delete
Rancho RS 5000 Shocks
6.4 Banjo Bolts
Throttle Plate Delete
4" Straight Pipe
Updated to "Blue" Fuel Pressure Spring
DIY Coolant Filter
Caterpillar EC-1 "RED"
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin, 1759
shiprek is offline
post #6 of 8 Old 04-19-2011, 05:12 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Just run the Rotella T6 5w40. I switched to that on my last oil change and can already tell a huge difference.
dhanna6powerstroke is offline
post #7 of 8 Old 04-19-2011, 05:15 PM
duc796's Avatar
Amsoil makes a 15W40 full synthetic along with 10W30 and 5W40. I am a Amsoil dealer, let me know if you are interested!
2005 Ford F250 CCSB 6.0 XLT 4x4
-SCT X3 W/ Innovative and Spartan Tunes
-4" MBRP Turbo Back Exhaust
-MBRP Cat Delete Pipe
-S&B Cold Air Intake
-Amsoil Everywhere
-CAT ELC
-Zoodad Mod
-Edge Insight CS with Pyro
-Sinister Diesel Coolant Filter
-Studded and Deleted
-6.4L Banjo Bolts
-2.5" Top Gun Customz Leveling Kit
-Bilstein 5100 Shocks
-35" General Grabber AT2s
Best track time: 14.1 @ 96MPH
duc796 is offline
post #8 of 8 Old 04-20-2011, 05:40 AM
Chapter Director
cubalz's Avatar
Holy crap, How many miles do you drive a month????
2004 F350 6.0L Power Stroke Diesel
4.5" Lift
37 x 13.50 x 16 Pro Comp Extreme AT Tires
Mickey Thompson Classic II Rims
Power Tow Mirrors
Ranch Hand Front Bumper
Bully Dog RFI Intake
Bully Dog Outlook/Triple Dog Power Pup
ARP Studs
Blocked Off EGR Cooler
5" Exhaust Tip
Low Profile Toolbox
Prodigy P2 Brake Controller
Kenwood In Dash DVD Double Din Radio
HFCM Water Separator Drain Plug
Dieselsite Coolant Filter Kit
cubalz is offline
