Flush your coolant!
Whether your Pro ELC or Pro Ford Gold, I'd still recommend flushing your system and installing a coolant filter. I may have been a little to late, hence the reason my rigs' in the shop getting a new oil cooler, EGR cooler, and headgaskets.
Initial draining of the system, before I installed a coolant filter. This WAS a clean jug. ![]() This was towards the end of the drain. Mmmmm casting sand. ![]() First jug: Initial drain. Second jug: First flush. Third jug: After adding VC-9
Great pix! Keep em coming through the process.
Roger |
This coming weekend is truck weekend!
Last Friday I picked up a gallon each of Restore and Restore Plus from Cummins. Also got 5 gallons of Zerex ELC Concentrate (to have 1 on hand for spare) and a few new coolant filters. Just have to pick up a new thermostat (going to change it to be proactive and since I'm going to remove it for flushing), cases of distilled water and I'll be set for this weekend! Plans are to drain out, flush with tap water to get as much of the regular coolant out, Restore Plus followed by more flushing with tap followed by Restore and then flushing with distilled. Then, last but not least, new thermostat and fill with 4 gallons Zerex ELC and distilled water to top it off. After all this is done, will change the oil to Amsoil 5-40 and installing Firestone Ride-Rite on the rear. Fun will be had this weekend!
Wow. Your jug comparison is amazing. I did 5 flushes of just the radiator (short on time / quick job after work) and it was coming out somewhat clear. Once I got time on saturday I did 2 full flushes pulling the plug on the block and both times it looked like jug #2. Going to do Restore and Restore plus flushes this weekend. Thanks for sharing!
