new truck - Ford Powerstroke Diesel Forum
Old 04-17-2011, 06:42 PM
SOOPAH DOOTIE
new truck
I am in the process of making a deal on an '03 6.0 CCLB DRW Lariat FX4 with 91000 on the clock. I was on an extended test drive and the egr cooler goes out.. It is a very clean truck and pretty much evey thing I want, the dealer is going to pay for the repair at my mechanic who is doing the job (delete new oil cooler flush and change coolant and change oil filters, and re-flash the computer). Is there anything else I should worry about in the near future? Thanks.
Old 04-17-2011, 06:49 PM
Find out how much your mechanic will charge to go deep enough to add ARP's to it. He will be very close to them at that time.
Old 04-18-2011, 08:42 AM
Change the coolant to a CAT EC-1 rated ELC.
Old 04-19-2011, 04:23 PM
SOOPAH DOOTIE
Ok it is in the shop being worked on right now, the wife hit up the Cat dealer and got the coolant, it should be done tonight or sometime in the morning
Old 04-20-2011, 06:22 PM
SOOPAH DOOTIE
Pic of new truck w/ my 20' stock trailer in my sig
Old 04-20-2011, 06:25 PM
SOOPAH DOOTIE
Nevermind I can't figure this out
Old 04-23-2011, 05:43 AM
SOOPAH DOOTIE
Ok I got it. Truck is fixed and runs like a champ! Now time to figure out add ons, SCT, 4 or 5 inch, and a cold air kit for starters.
Old 04-23-2011, 06:14 AM
Feedback Score: 3 reviews
Save your money and your turbo, don't get a CAI. Your not gaining any real power with a CAI. The stock air filter can support up to 500hp. Most CAI don't filter out enough dirt, and them dirt particles that get past the filter can/will destroy the compressor blades.
Old 04-23-2011, 10:15 AM
SOOPAH DOOTIE
As I am new to the 6.0 does anyone know of some cheap/free mods that I can do untill I get the money for the other stuff?
Old 04-23-2011, 10:54 AM
6.4L banjo bolts, FPR upgraded spring kit, guages to monitor Eot & ECT, Boost, EGT and Fuel Pressure, since you tow a good trans temp guage also....upgraded drain plug on the fuel pump on the frame near drivers side door, especially if its a 4wd truck. can get part #'s if needed.
