i was thinking about buying a 6.0L PSD and building up the motor and putting it in a Ranger, i know there would be a lot of fab work but i am capable of doing it. does anyone have any ideas of what parts would be needed to make the truck handle the weight and the power of the motor? i was thinking a 9" rear end with a dana 44 solid axle up front and some frame mods. and did i mention i want to do a custom motor build with triple turbos?
Adam from FCDP has a 6.0 in a ranger, you might wanna talk to him about the suspension work they did.
thanks, i just want something different that you dont see everyday
Sounds like you want it to be 4wd? Are you building it to race or what? I would pick diffrent axles if I were you.
There are 2 rangers with 6.0s in them. Both are 2wd lowered striped down race trucks. Also triple turbos is alittle over kill and pointless. |
Here ya go
This ones got a cummins in it but still b!tchen! |
it would be for wheeling and daily driver. it would be different of course but i've seen a triple turbo cummins for a daily driver. i've always wanted to build up a powerstroke and i finally have the time and money to do so
Just because you saw triple turbos on a cummins doesnt mean you can make a set for a 6.0 just as easy. Let me tell you when you start adding more turbos to 6.0s it becomes a art. To master that art it take alot of time and most of all alot of money. There is one triple turbo 6.0 in the works, guy by the name of tad, Owns Elite Diesel, and its having problems. I dont think you should try triples. If you are stuck on putting a 6.0 in there and want serious power just put some 190s and a powermax in there and thats 550hp and it that ranger will be way more than enough for you and its about a billion times easyer. Dont get me wrong I love the idea of a swap. Just not in a ranger for wheeling. I have a prodject that is kind of on the back burnner because of my procharger truck that is a 67 F-250 4x4 and im putting a 6.0 or 7.3 in. That swap is alot easyer because you can use the frame and all the running gear. just my thoughts of the matter Last edited by 06powerstroke06; 04-17-2011 at 11:08 AM. |
well thanks for your feedback. i'm gonna think about it a little more and i was thinkin maybe even a bronco with the 6.0, i've seen one with a 7.3 and it was badass. but whatever happens, i'm puttin a 6.0 in something lol
Bronco is alot better! that would be very fun! I remember seeing a bronco with a 7.3 and thougt it was very cool.
As long as its not the bronco II
i just want to do another swap because i just got rid of my 95 f250 12 valve cummins, it's just something cool
| Tags |
| powerstroke, swap |
