should i do it now or wait? - Ford Powerstroke Diesel Forum
Old 04-17-2011, 08:13 AM
ok so i have an 03 6.0, i have collected everything i need to do egr delete, new oil cooler, vc-9 and restore.
i was planning on doing it all at once.
however last week i blew my turbo, so i am now awaiting the arrival of a powermax.
so my question is, while i have it apart should i do the egr delete and change the oil cooler, then put the turbo on and do the flush, or should i put turbo on, do the flush and then egr delete and new oil cooler?
thanks
Old 04-17-2011, 08:15 AM
Feedback Score: 9 reviews
Do it all at once.
Old 04-17-2011, 08:29 AM
Powerstroke Techie
Feedback Score: 3 reviews
do it all at once or you'll be doing the turbo twice
that's good logic on my part
Old 04-17-2011, 08:46 AM
That was my thinking as well. I guess my main question or concern is flushing the system with the new oil cooler in. I am worried it may clog. Wasn't sure if I should flush with the old stuff in then change everything out. Or if it was ok to flush after replacing everything.
Old 04-17-2011, 01:25 PM
Anyone want to chime in on when i should flush the coolant system? before or after i change the oil cooler?
thanks
Old 04-17-2011, 02:01 PM
flushing
thanks
Rock,
I have an 04 with 100k miles, all original. I am currently running 13° delta at steady highway speeds. I am ordering my coolant filter kit tonight and plan to do multiple flushes including the Restore and Restore+ before I change my oil and egr coolers. I am still trying to figure out a way to reverse the flow (backflush) thru the egr and oil coolers to see if I can get better cleaning that way, but have not come up with a plan yet. Good luck on your work.
Roger
Old 04-17-2011, 03:15 PM
only flush before doing the oil cooler, it will only plug up the new one if you do it after
Old 04-18-2011, 08:57 AM
Send a message via Yahoo to DaDeerHunta
Yes do the flush before or you will be buying another oil cooler
