New to diesels - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-16-2011, 11:46 PM Thread Starter
New to diesels
I am deployed right now and just bought a 04 6.0 on leave and I bought an Edge Evolution, K&N FIPK Cold Air Intake, and an MBRP 5 in Turbo-Back. Is there anything else I should get alongside this stuff and will the exhaust fit I've read about the 4 in having clearance issues. I was thinking about ARP head studs but I heard you have to remove the cab to do so is that true, cause I was planning on doing it in the driveway?
dwpayne is offline
post #2 of 4 Old 04-17-2011, 05:50 AM
legionxxii's Avatar
I would return the Edge and Cold Air intake and get a SCT tuner with custom tunes and a Edge Insight for gauges. The exhaust will clear plenty of people run 5". You can still do studs with the cab on its just harder due to lack of room but it has been done before. I would replace your coolant with ELC and get a Coolant filter also. Also go over all your fluids
2006 Ford F250 King Ranch CCSB Stock for now
Sold 2003 Ford F250 Fx4 CCSB 4" Turbo Back Straight Pipe With 6" Tip Egr Delete 6.4 Banjo Bolts Blue Fuel Spring Upgrade Cat ELC Coolant Coolant Filter Edge CTS SCT With IDP Tuning PHP FICM Tuner Zoodad Mod Track Time: 13.747
US ARMY 13F
legionxxii is offline
post #3 of 4 Old 04-17-2011, 07:54 AM
duc796's Avatar
What he said
Theres a lot of great info on this forum and a lot of people who know a lot about these trucks that are more than willing to help ya out if you need it. Do some research and learn about what your truck likes and dislikes.
2005 Ford F250 CCSB 6.0 XLT 4x4
-SCT X3 W/ Innovative and Spartan Tunes
-4" MBRP Turbo Back Exhaust
-MBRP Cat Delete Pipe
-S&B Cold Air Intake
-Amsoil Everywhere
-CAT ELC
-Zoodad Mod
-Edge Insight CS with Pyro
-Sinister Diesel Coolant Filter
-Studded and Deleted
-6.4L Banjo Bolts
-2.5" Top Gun Customz Leveling Kit
-Bilstein 5100 Shocks
-35" General Grabber AT2s
Best track time: 14.1 @ 96MPH
duc796 is offline
post #4 of 4 Old 04-17-2011, 08:07 AM
The first big problem I see is the K&N intake. They are known to dust turbos. The stock intake is good up to 500 hp so with a tuner you'll be just fine with that. 2nd the Edge. Tune on the fly hurts your transmission. An SCT with custom tunes will tune your transmission along with giving you the "safe" power. What people are talking about with your exhaust is the 4" down pipe. MBRP doesn't use a 4", they use 3.5" I believe so that shouldn't be an issue. The biggest thing with a 6.0 is gauges. Make sure you know where your motor sits before tuning it. Like the guys above said get a good monitor first. That will tell you how healthy your critical parts are. Hope that helps! and congrats on the new rig
2016 F250 Lariat
the06wildebeast is offline
