ICPv and Psi help.
So I'm trying to understand the ICP readings, just took my truck for a run and here is what I got-
Cold Idle 1.2v/910-920psi Warm Idle .9V/580psi Up hill @40mph 3.3v/2900psi Cruising @40mph 1.4v/1000psi So does this look normal to you? Im just trying to get an idea so I know when I have problems. Oh and what numbers should I start to worry at? I would like to set the warning alert on my CTS so I can know. Thanks. P.S. Truck is completely stock and any other info is in my sig. |
More info
Lets talk ICP and DC% |
ICP_DES 0 625.5 1400 - 1450 0 - 4045 PRESSURE (PSI) ICP Desired
Key on = 0 Low idle=625.5 high idle=1400-1450 Operating range= 0-4045 all these are psi. Ford specs. |
So according to this chart I'm right where I should be, I can hit 3900, but the chart doesnt show that. What would be good numbers to set my Voltage and PSI alerts at so I know when I have problems? And its on a CTS insight so I can only do one way, if it goes to high or low, not both....if it matters.
Give a man a fish, and he eats for a day. Teach a man how to fish, and he eats for a lifetime. |
