'06 F-250 Head Gasket - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-14-2011, 08:10 PM Thread Starter
Question '06 F-250 Head Gasket
My truck currently has 198,000 miles on it and has started losing coolant. Especially when towing my work trailer.
I took it to my local Ford Dealer mechanic (who has been pretty trustworthy) and he checked it out and said that he thinks I need new head gaskets.
I have a few different questions:
1. Is there any way to definitively conclude that I need the head gaskets?
2. If/when I get the head gaskets done, what else should I replace/check? (Besides studs and possibly the BPD egr cooler.)
2a. Is there any advantage to modifying the exhaust while the cab is off?
3. Since I put quite a few road miles on my truck, how can I reduce the noise inside the cab to as quiet as possible?
Thank you all in advance for your thoughts and advice.
Red1Rooster69 is offline
post #2 of 14 Old 04-15-2011, 02:26 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Rebuild oil cooler, STC fitting, Standpipes and dummy plugs
Powermax turbo, 175cc injectors, new tunes.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 14 Old 04-15-2011, 03:32 AM
Chapter Director
cubalz's Avatar
If you are planning on ever installing a turbo back exhaust system. Putting it on while the cab is off is a smart move.
Regarding noise: 6.0's are noisy (I personally LOVE it. I want my diesel to sound like one) The only thing that would maybe help would be to tear out the interior and put down some dyna mat sound dampening material on the inside. Other than that - The brand new ones are quiet.
2004 F350 6.0L Power Stroke Diesel
4.5" Lift
37 x 13.50 x 16 Pro Comp Extreme AT Tires
Mickey Thompson Classic II Rims
Power Tow Mirrors
Ranch Hand Front Bumper
Bully Dog RFI Intake
Bully Dog Outlook/Triple Dog Power Pup
ARP Studs
Blocked Off EGR Cooler
5" Exhaust Tip
Low Profile Toolbox
Prodigy P2 Brake Controller
Kenwood In Dash DVD Double Din Radio
HFCM Water Separator Drain Plug
Dieselsite Coolant Filter Kit
cubalz is offline
post #4 of 14 Old 04-15-2011, 05:33 AM
StrokinBig's Avatar
Send a message via AIM to StrokinBig
if your loosing coolant its more than likely head gaskets. thats what mine was at only 90,000 miles. as advise from me to you, do the job quickly or it will mess up other things due to overheating from low coolant. make sure you put black onyx head gaskets with arp head studs to prevent it from happening again. i tried to put it off for as long as possible. when i finally got around to it i had to pay for new head gaskets, studs, egr delete, AND 2 new heads because both of mine were cracked. hope this helps man!
2005 F-350 6.0L
King Ranch/Lariat
8.5" skyjacker suspension lift (custom additions)
40" super swamper M16's on 20" moto metal 950's
airaid cold air intake and filter
5" MBRP turbo-back straight pipe
arp head studs
EGR delete kit
SCT tuner with Innovative Diesel tune
custom "smoke switch"
StrokinBig is offline
post #5 of 14 Old 04-15-2011, 05:56 AM
Galaxie's Avatar
Are you doing to do the job yourself? If so, let us know. There are some good write ups on all of this. If you have the space to take the body off and you have some free time, do it yourself!
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #6 of 14 Old 04-15-2011, 06:35 AM
Pipewelder71's Avatar
It also could be the EGR cooler, might want to check that.
How do you like me now.............
2005 F-350 CC SB FX4 Lariat, 6.0,
SCT X3 with Spartan Tunes
MRBP 304ss 4" exhaust
Autometer 4-gauge pillar w/ Ultra Lites II
ARP head studs
Modified EGR and Up Pipe
MagHy-Tech tranny pan
2.5" Cage leveling kit
Dieselsite coolant filter kit
Upfitter switches: #4 high idle
Custom built traction bars
Zoodad
Pipewelder71 is offline
post #7 of 14 Old 04-15-2011, 07:04 AM
have the valve guides checked too. my truck 170,000 miles waiting on heads right now to get done all valve guides were bad.
ASE Master Certified Technician
04 Powerstroke lovin it
thenubsterman is offline
post #8 of 14 Old 04-15-2011, 08:45 AM
You can determine if it is the head gasket by checking the amount of pressure in the degas bottle. Get a good pressure gauge and a really long hose, and T it into the line going to the top of the degas bottle. You can get this stuff for cheap at a parts store, or they have a "hero kit" I have seen at powerstrokehelp.com "Hero Kit" Rental... aka Diagnostic Pressure Kit Rental I made my own.
Anyway, you want to go for a drive, this guy explains it better than I could ever type:
That will help determine if it is a BHG or the EGR cooler. I made one of these, and convinced the sellers of several trucks to let me test before I bought. Two of the trucks I looked at had blown headgaskets. Glad I did not purchase those!
As for the exhaust, I would for sure not put it on with the cab off, because there is no way to see what the clearance will be with the downpipe to the cab. Sure it will be easier to put on, but you are going to have to loosen and tweak once the cab is back on anyway, so you are basically doing it twice. I specifically did my exhaust with the cab on. Just my 2 cents.
2006 F250 FX4 Crew Cab - ARP Studs, EGR Delete, Edge Insight w/pyro, SCT X3 with SRL+
2005 Mustang GT - slightly modded
1986 F250 IDI 4x4 ZF5 - Sold
1979 Bronco 460
1967 M35A2 Deuce w/winch FOR SALE!!!
emperorjordan is offline
post #9 of 14 Old 04-15-2011, 09:45 AM
PGreenSVT's Avatar
That guy is a total a$$hat and you can not tell whether it is a head gasket or an egr cooler by the pressure reliably. When coolant flow is restricted to the egr cooler because the oil cooler is clogged the reduced amount of coolant in the egr cooler will flash boil when the egt's climb.
What happens when the coolant flashes? Yes, that's right, you get high pressure in the coolant system. That is what ruptures egr coolers.
You can test the degass bottle for the presence of exhaust gasses as a reliable test for blown head gaskets.
RIP Mitch
the Org crew
post #10 of 14 Old 04-15-2011, 09:46 AM Thread Starter
I won't be doing the job myself. I've actually got less time than money at this point, although not much of the latter either.
My mechanic will install anything I decide on, so I just want to make sure that I won't have major issues past this one, that can be prevented. I would love to post back at 500,000 miles praising the advise in this thread.
Thanks for the advice already given, and keep it coming. With the price of new trucks these days, this one is going to have to last.
