2003 f350 6.0 - Ford Powerstroke Diesel Forum
Old 04-12-2011, 04:47 PM
2003 f350 6.0
I have code p2285 Injector control pressure sensor circuit low. I picked up a sensor from ford and a diagram on sensor locations. Looks like its on passenger side under alternator on the valve cover. on my truck it is not in that location. Can someone point me in the right direction please?
Old 04-12-2011, 04:56 PM
behind the turbo
Old 04-12-2011, 05:31 PM
When I replaced mine I was able to get at it best from under the truck. It is however a real PIA to remove and replace. Also be sure to inspect the pigtail as they are known to get damaged. replacements are available from ford.
Old 04-12-2011, 07:41 PM
Feedback Score: 3 reviews
http://www.forddoctorsdts.com/articl...icle-10-06.php
Here are some manuals on part locations.
http://www.forddoctorsdts.com/articl...icle-06-08.php
Old 04-13-2011, 02:48 AM
That was my first repair on my truck. I got to it from under the truck as well. The hardest part was removing that heat shield, one of the bolts is very difficult to get to. Once that shield is off the replacement is quick.
Old 04-13-2011, 03:30 PM
I pulled heat shield off and I can't see sensor anywhere on the back of engine or on top of the rear engine. I even got a mirror and tried to look.
Old 04-13-2011, 04:32 PM
The '03-early '04's are behind the turbo, on top of the engine valley. It's not the easiest to see, but if you reach back there, you will feel two sets of wire connectors. The front one is the IPR. The back one (closes to firewall) is the ICP.
The late '04-'07, have the ICP on the passenger side valve cover, right above the Glow Plug Module, toward the front of motor.
