2004 standpipes and dummy plugs - Ford Powerstroke Diesel Forum
Old 04-12-2011, 08:07 AM
I have a 2004 build date of 2/2004 I am getting ready to do arps, oil cooler, head gaskets, and just about everything that I have read to change along the way. My question is, since my truck is an early 2004 build do I need to get the updated standpipes and dummy plugs? From the reading I have done I am thinking that the early ones did not have the same problems as the late 2004's and on. Any info would be appreciated
Old 04-12-2011, 03:14 PM
Powerstroke Techie
Feedback Score: 3 reviews
if you have a wavy rail you should still get the new style standpipes. they have updated check valves and d-rings
dummy plugs probably aren't necessary on a 04
Old 04-12-2011, 03:35 PM
i didnt think the '03/4 had these?
Old 04-12-2011, 06:30 PM
From the reading I have done I know there is something different about them just dont know exactly what. Guess Ill find out for sure when I get it apart.
Old 04-12-2011, 06:33 PM
Powerstroke Techie
not all early 04s (built in 03) are the straight rail design
if you have an ICP sensor on the right valvecover you have a wavy rail
04 dummy plugs are a 1/2 drive plug where as the 05-07 dummy plugs that tend to go bad are a 10mm hex drive
confused yet?
Old 04-12-2011, 07:28 PM
You can find info and pics of the parts in the 6.0 manuals. Click and read.
http://www.forddoctorsdts.com/articl...icle-06-08.php
Old 04-12-2011, 07:36 PM
Powerstroke Techie
confused yet?
The OP might. But I'm not. Yes, I agree that only the lower d-ring on the dummy rail plugs tend to deteriorate on the ones that used the 10mm allen head plug as opposed the ones on late-2004 and early-2005 engines that used the 1/2" square drive style plugs.
Old 04-13-2011, 05:19 AM
Ok so I have a wavy rail with the good plugs minus the lower d-ring. And I do need the updated standpipes. I know I will find out for sure when I get in there but I want to make sure I have all the parts before I start. Thanks guys for the info.
Old 04-13-2011, 02:19 PM
And yeah Im a contractor not a ford master tech so im sure that I am more confused that you lol. But I have done enough reading to figure most out and I have a good buddy that is a diesel tech so Im sure I will make it through the process. I just wanted some second opinions on things. Like I said thanks for the good info guys.
Old 06-27-2011, 07:44 AM
What are the part numbers for the updated stand pipes and dummy plugs?
