EGR question?
I was at a Diesel shop the other day talking to the mechanic about an egr delete kit. He said well I'll save you a couple hundred dollars. He popped the hood and disconnected a conection on the top front of my motor. He said that that will stop the gate from opening and bypassing the egr. My question is, is this true and should I run my truck like this? Please inform.
Correct, all he did was unplug the EGR valve. That does not eliminate thew possibility of the egr cooler failing if the oil cooler clogs. I'd look elsewhere for a mechanic that understands the 6.o.
What they said^^^^
Also with certain year trucks and certain stradegies, when you unplug the EGR valve, it causes issues like clutch fan not getting to full RPM, and VGT won't cycle. |
Is this related to the 05+ trucks? Just curious. My buddy did an EGR delete on his 06 and ordered Matt's SRL tune. Matt told him to leave the EGR valve in and connected because of the fan issue.
http://www.ford-trucks.com/forums/97...egr-valve.html http://www.thedieselgarage.com/forum...d.php?t=102838 |
