Any reason why you couldnt use restore and restore+ at the same time?
Just wondering if there is a specific reason why you couldnt just use both products at the same time and save some time. Thanks
YES. One is a base one is an acid.
One will cancel out the other. Restore is a very high pH (10-12) alkaline cleaner and Restore + is an acid base or very low pH cleaner (1-2). If you add then togeather you will end up with a mixture likely around pH 6 (water is 5-6)
