Wiring question - Ford Powerstroke Diesel Forum
Old 04-11-2011, 07:01 AM
Wiring question
Mouse nest behind passenger battery. Using the battery insulation to make a nest! Anyway, they also chewed off insulation on a green wire with red tracer that is just a short wire (2 inches) that is looped in a connector that plugs into harness behind the battery. Anyone know what this connector is? I repaired the wire with a new wire and heat shrink but curious to what this connector is for.
Old 04-12-2011, 07:31 AM
...anyone??
Old 04-12-2011, 07:40 AM
Illiana Chapter Director
I just went and looked at mine and don't see that connector at all. Does you truck have auto 4x4?
Old 04-12-2011, 07:52 AM
Retired Soldier!
usually if it is looped back in the connector it is to complete a circuit if you do not have the option. May be to outside air temp in the overhead monitor. I will look at my truck.
Old 04-12-2011, 07:56 AM
I have a green wire with red tracer in a harness but it is connected to the vacuum solenoid for the 4x4. That's why I wondered if his was auto 4x4 or not.
Old 04-12-2011, 10:06 AM
I notice the same wire on mine yesterday while changing out the battery. Also curious as to what it does
Old 04-12-2011, 11:11 AM
Yes, mine is a 4x4 with auto trans. It looks like the connector comes out of the harness leading to the right headlight, but I can't be sure. The connector unplugs and you're left with two bullet type of connectors that are either end of the looped green wire with red tracer. I have looked at some schematics of the area but nothing is called out.
Old 04-12-2011, 11:16 AM
Does it have Auto 4 wheel drive, (switch on dash)?
Old 04-12-2011, 11:19 AM
yes it does.
Old 04-12-2011, 11:22 AM
yes it does.
then. My truck doesn't have that wire unless I'm not looking in the right place. Can you get a pic.?
