scanguageII questions - Ford Powerstroke Diesel Forum
Old 04-09-2011, 06:21 PM
can the scangaugeII get the ficm vlts??
Old 04-09-2011, 06:24 PM
Yes it can, you would enter the following Xgauge codes:
FICM Vehicle Power (Volts) (Should be 12 Volts)(should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
FICM Main Power (Volts) (Should be 47-48) (this does work! )
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
And more Xgauges in the following thread:
Some Scangauge II Codes for "Xgauge"
Old 04-09-2011, 06:31 PM
what should my ect and eot temps
Old 04-09-2011, 06:35 PM
Depends, basically, flat ground highway speeds is where you will check those temps.
Mine runs 188* to 190* on ECT
MY EOT runs 194* to 197*
Old 04-09-2011, 06:38 PM
my was ect 180 and eot 182 is that bad
Old 04-09-2011, 06:40 PM
How long were you driving? 20 minutes should be long enough to warm it up. If you were out there that long and still showed those temps, I'd be looking at a new "T stat".
Old 04-09-2011, 07:16 PM
it was around 20 min i get to flush the system and do a new t stat and put the egr delete on just havent had the time and just got my scangaugeII but you dont think anything is wrong
Old 04-09-2011, 07:35 PM
where can you get all those codes for the scII ??
Old 04-09-2011, 07:44 PM
Here are some for the 6.0
Old 04-09-2011, 08:04 PM
hey do you know how to the guy on powerstroke nation
