Gonna do brakes and what else?? - Ford Powerstroke Diesel Forum
Old 04-09-2011, 05:47 PM
Alright guys so i have an 04 f350 cc/lb dually and i need to do brakes all around and was wondering whatelse to check while im in there like hubs etc. i am planning on doing the front axle u joints while im in there so if someone could please provide a parts list on that that would be great!
im thinking of just running motorcraft brakes as i get a discount at ford. these are the prices i got
front pads $67.90
front rotors $144.46 per side
back pads $67.96
back rotors $135.96 per side
slide pins and boots $23.74 per wheel
i do have what seems to be a clunk noise when i turn at low speeds almostsounds like body shifting?? i did do the ball joints about 30 000km ago.
any info and help would be greately appreciated
Old 04-09-2011, 05:51 PM
Illiana Chapter Director
front pads $67.90
back pads $67.96
If you do the u-joints, you'll have to redo all the axle seals that were done when the ball joints were done. Check your sway bar bushings and link bushings for the clunk noise.
Old 04-10-2011, 03:35 AM
IU Hoosier Fan
^^^^^^^^ Speaking from experiance
Old 04-10-2011, 10:32 AM
i can grab my sway bar and move it side to side easily... i take it the bushings are shot?
what do you guys think of the brake part pricing??
Old 04-10-2011, 11:03 AM
Just out of curiosity, how many miles do you have on your rig?
Old 04-10-2011, 05:39 PM
Rotors seem high to me. Check these guys out -----> Brake Rotors Discs Pads Brakes Cross Drilled & Slotted I just put the slotted and dimpled rotors and their pads on an 05 F-250 and the guy really likes them. Najaf4life just put them on his Ex. and is pleased. You can get all 4 rotors and pads for around $400
Old 04-11-2011, 01:03 PM
Feedback Score: 5 reviews
You could add a 5 line SS brake kit..we have them..
Old 04-11-2011, 01:31 PM
I found on my 03 that the rear backing plate for the brakes is rusted through. You may want to check yours since you'll be in there. Also make sure that the brake pins glide smoothly and are lubricated.
Old 04-11-2011, 01:36 PM
Change your fluid to dot 4. I am doing that soon.
Old 04-14-2011, 05:32 PM
i have just under 208 000 km on my rig
whats the advantages to stainless steel brake lines? firmer pedal??
whats the advantages of dot 4vs dot3brake fluid?
thanks for all the advice guys!
also how does one check to see if hubs are wore out?
