Oil Advice
So I was having some injector stiction issues earlier on in the winter, I switched from the Motorcraft 15w40 to Rotella T5 10w30 with Rev-X additive. It worked out for the colder weather and injector issues. Now summer is around the corner and temperatures are going to be 80-100*s. I'm looking to switch to another oil.
My buddies have had good luck with Amsoil, I'm looking at their full synthetic. What is going to be the best option for my truck, between 5w40 and 15w40? Any advice is greatly appreciated. |
![]() 2 stroker
For years I've been running amsoil 15-40. However, I just ordered and received a case of amsoil 5-40. I usually don't run the truck in the winter months (much) but feel the 5-40 will do well year round.
Rottella or mobil 1. 4w-40 all year long.
both 15w-40 and 5w-40 are good to use in the summer over a 30w oil.
If you want to upgrade the 5w-40 syn oils, rotella is a cheap upgrade. If you want better go with mobil1. |
5w40 will always be better for the injectors on a cold start. Once at operating temp there is no difference between the 5w40 and the 15w40.
Yup, and 5w-40 will be better than 10w-30 for cold starts.
Thanks for the advice, sounds like I'm going with the 5w40 then.
Ah wait, so as I'm reading it, 5w-40 is o.k. for summer temperatures in the 80-100* range?
I'm running Royal Purple 5W-40 in my 05' not had a problem to date. I am going to install an bypass filter around the same time I do my next oil change thou, just for the extra safety factor.
