Surging? - Ford Powerstroke Diesel Forum
Old 04-08-2011, 06:02 AM
Surging?
When my truck is cold it seems to really chug until it warms up and even a couple miles down the road I get on the Highway and if I set the cruise on 60 it will surge/chug until I get on it or back off the cruise. It seems to only last until it warms up but now it seems a little more common. Is this normal or could it be the tune
Daily driver with of 5-6 mile trips
Changed oil/filter
Changed fuel filter(s) too
06 f250 w/innovative custom tune
Old 04-08-2011, 07:17 AM
Check your FICM voltage. Classic behavior for a FICM on its way out. FICM should maintain 48v while running and starting. If it drops below 46v your FICM is bad and needs to be replaced. If it is bad get a Swamps Diesel 58v replacement. Much better and cheaper than the OEM Ford rebuilt part.
Old 04-08-2011, 09:27 AM
Thank you for the response but what is the FICM and where is it?
Old 04-08-2011, 09:31 AM
Fuel injection control module, it's mounted to the valve cover on the passenger side I believe. It's about the size of an iPhone but thicker
Old 04-08-2011, 09:36 AM
It's a whole lot bigger than an iPhone
Old 04-08-2011, 09:38 AM
As stated above it is on the driver side valve cover.remove the small inspection plate and there should be 4 pins. With a Digital Multi Meter set to volts check voltage by putting one probe on the bottom pin closest to the fender and the other probe on the neg. terminal of the battery. Check while running and cranking. It should not fall below 46v. If it does take the FICM off and send it to Swamps Diesel for a 58v rebuild. It is cheaper and more robust than a Ford replacement.
Old 04-08-2011, 10:55 AM
Awesome guys..thank you all very much! Do you know how much that should be and I take it that the truck cannot run while its being fixed?
Old 04-08-2011, 11:07 AM
Correct, the truck will be down if you send them your FICM. The Cost for the Swamps 58v FICM is $450 if you send yours or $800 with a $350 refundable when you send your core in if you just buy one that is already done. PHP's programming is another $150 if you want to go that route.
circuitboardmedics.com also rebuild FICMs. Their standard 48v repair is $325. They will also do a voltage upgrade but I don't know the cost.
Old 04-08-2011, 11:18 AM
Slacker
Feedback Score: 4 reviews
Thanks, Mitch! I checked out that site and if my wife's washing machine ever goes belly up, it sounds like they can fix the circuit board for that too!
Old 04-08-2011, 11:26 AM
We aim to please!
