Want to do it right once ! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-07-2011, 07:59 PM Thread Starter
Hey guys, I am currently in the process of the cab off head gasket job... the dealer is doing it so its kinda pricey but none the less i only want to do this once!
The truck tows most days of its life and is always on the road, I am doing the injectors and EGR delete as well as the head gaskets and ARP studs. I have been told to do the oil cooler while im there so probably that too.
What else needs to be done to ensure reliablity and sleepability knowing i put 15,000 worth of work into my rig ?
Also what else can i do after its done to help out? is there a certian oil i should run or coolant?
ClutchR16.0 is offline
post #2 of 5 Old 04-07-2011, 08:14 PM
2003kingranch's Avatar
if you dont already have exhaust do it! especially if your doing a lot of towing it will keep your egt's down
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #3 of 5 Old 04-07-2011, 08:25 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
What year truck? There are upgraded factory parts that can be put on. Clean the turbo.
While the heads are off, send the heads to a reputable machine shop to check for flatness and cracks.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 5 Old 04-07-2011, 08:34 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
If you don't mind me asking, where abouts in Ontario are you located? What is the model year of the truck? What's the name of the dealer doing the work? Is that $15,000 inclusive of all parts and labour? Even so, that does sound a little steep. The work you describe could likely be done at my dealer for half of that.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #5 of 5 Old 04-08-2011, 07:00 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Use a CAT EC-1 spec ELC coolant and a 5w40 synthetic oil.
RIP Mitch
the Org crew
PGreenSVT is offline
